HKF
- Jul 18, 2021
- 3,244
- 6,164
- Benimar Europe 740
- Since August 2021
How do I know what my tyre pressure should be, please? Thank you
Just used that site to check mine and for some reason its way off, with the correct axle weights on each of the 3 axles on my tag it comes out at 44 psi on the rear. If i put that in it would be dragging the floorThis will help if you know the axle loads.![]()
Motorhome Tyre Pressure Calculator | TyreSafe
Our motorhome tyre pressure calculator gives you the correct pressures for your motorhome. Check your tyres regularly for your safety.www.tyresafe.org
That is a max inflation figure but it only applies to the American market, so you can ignore it.some say to go by the figures on the tyres themselves. And then, some say that the figure on the tyre is the maximum and that inflating to that pressure risks a blowout
The correct pressure is directly related to the axle load and the tyre load rating, so you should have tyres fitted with the correct load rating or higher, it's not different makes that really make a difference it's the load rating figure, ie 112,116,121 etc, that is why it always comes back to knowing your axle weightsThank you so much for all the replies so far. One thing that's confusing me is that some say to look at the sticker on the door pillar and some say to go by the figures on the tyres themselves. And then, some say that the figure on the tyre is the maximum and that inflating to that pressure risks a blowout. The door pillar one has always confused me because surely it depends on what tyres you have? Anyway, I'll try to get to the weighbridge again soon and see what my axle weights are. Then I'll come back and let you all know, together with a pic of the sticker on the door pillar, so that I know what they should be![]()
I know this is what is said, but can you explain why, or what that means?That is a max inflation figure but it only applies to the American market, so you can ignore it.
No a clue, may be something to do with high temperatures in some states like Nevada.I know this is what is said, but can you explain why, or what that means?
Why do Americans need to know this, and no one else does?
Interesting, thanks. The readings surprised me a little. With my axle loads of 1850 and 2000 it gave me 53 and 80 psi. Then I put in 1850 on each axle and it still gave 53 and 80.This will help if you know the axle loads.![]()
If you put in CP tyres it always gives 80 on the rear, if you put your rear axle weight in front axle box you get a sensible pressure.Interesting, thanks. The readings surprised me a little. With my axle loads of 1850 and 2000 it gave me 53 and 80 psi. Then I put in 1850 on each axle and it still gave 53 and 80.
That was interesting thanks. So 53 front 59 rear then. Rounded to 55 and 60. Big difference!If you put in CP tyres it always gives 80 on the rear, if you put your rear axle weight in front axle box you get a sensible pressure.
Doing this my correct? Pressure came to 53psi front ,70 rear ,does this sound okay for a 3850kg ,7.4m A class?If you put in CP tyres it always gives 80 on the rear, if you put your rear axle weight in front axle box you get a sensible pressure.
My Michelin CP tyres say 69psi somewhere on the sidewall but the manufacturers have said squeeze in 80psi all round. I run somewhere in-between for comfort and 4 years and 30k later I'm still here to tell the taleOn my tyres there is no mention that the maximum permitted tyre pressure (69) only applies to the American market, is this a fact or urban myth, interested as door pillar says 79psi all round, although I do run at 60/65
Got my pressures from Toyo, front 56 psi @ 1930kg, rear 69 psi @2300kg.Doing this my correct? Pressure came to 53psi front ,70 rear ,does this sound okay for a 3850kg ,7.4m A class?
Front axle is 1850 rear 2240Got my pressures from Toyo, front 56 psi @ 1930kg, rear 69 psi @2300kg.
The gross weight is irellavant it's the axle weight tyre pressure is based on.
Those are the max what are the axle weights you run at?Front axle is 1850 rear 2240
Need to get to a Weighbridge then?Those are the max what are the axle weights you run at?
That is what you set the tyre pressures for.
Okay, so looked at labels and tyres and checked to get differing results.
Tyres are 225/75 16R 116
Label inside door says 5.5 bar
Other door has axle weights of
Axle 1 2000 and axle 2 1850.
If I go 1 = front then pressure in front tyres is 3.7 bar
If 1 = rear then pressure in fronts changes to 4.2bar.
Rears in both cases are 5.5.
The tyres were inflated to 3.7 bar all round by dealer at delivery.
It is a Fiat Ducato 6m PVC from Hymer.
So what is correct?
Axle 1 is Front.Okay, so looked at labels and tyres and checked to get differing results.
So what is correct?
That's ilrelavant those are max axle weights you set the tyre pressures for the actual weights you run at. So you have to go to a weighbridge fully loaded to measure the axle weights.Other door has axle weights of
