What causes drop in ...
movan
Moving around
Burstner
since07
What can cause a sudden decrease in mpg normally attained, please?
(I don't mean such as being heavy on the pedal or pushing revs etc .. I mean is there anything like diesel, oil, gear box, etc..)
Thank you.
Thanks both. I've just filled right up again and will check once more .. I WAS a bit heavy footed on last long journey but didn't expect it to affect consumption as much as it did.
Can't see a leak and tyres seem ok ..
If it happens again I will ask garage to check fuel pump and injectors.
I like to sound as though I know what I'm talking about when I go into a garage. ;)
What was the difference mpg?
Do you use an app to track the mpg or are you guessing?
Air filter would be my first call. Cheap and easy to replace too Joy.
What are the quotes for..Honda 50 ,?
quotes??
That just my little shed of a commute car I use while still in my work clothes a old 1994 Peugeot 106. One day I'm sure it will fall apart but it's been 15 years and I'm still waiting :D
Hills as already mentioned and Head winds will cause drops in MPG. If you are driving for an extended period into the wind then it will make a difference to your normal economy.
Letting the gap between me and the HGV in front grow to more than 6ft. Once a cyclist, always a cyclist -- tuck in behind the big guy when the wind gets up :-)
Vast. About a difference of 9 mpg. Have to be fair I am normally easy on the revs etc and this time desperate to get home I was well over speed limit for considerable distance. So it may be MY fault.
I have noticed our MPG always suffers when the temperature drops..
For instance, in January going to Spain we average 21.2 mpg
Coming home mid March it goes up to 22.5+ MPG
This has happened every year for the past 11 years .. and we are always heavier coming home than going
