Whale water system pressure switch
John R. Edwards
Walsall
Bailey 540
newbie
I have a Bailey 540 motorhome which has a Whale pump water system. This weekend when I turned a tap on no water came out of the taps. If I hold down the pump on switch on the control panel the pump runs, pressurises the tap water and if I open the tap, some water comes out then stops although if I leave the tap open and hold down the pump on switch, water comes through as normal. I assume there is a fault on the pressure switch. However, I cannot locate a pressure switch! I can find the Watermaster pump and the surge damper. There are no microswitches on the taps.
Any ideas/suggestions appreciated
Is the pressure switch part of the pump? If not follow the wires.
I've seen that on the Whale website but can't find anything similar in my motorhome.
I can see the pump (blue) and anti surge thingy next to it (white) but no pressure switch.
It must be in the pump, is there any water coming out under the motorhome when it's running?
