After a smallish [ 200kg] uplift in the weight capacity of our stock 3500kg Ducato based Sunlight, to 3700kg we found the 2000kg back axle limit was limiting our fully exploiting the gain made. The first uplift didn't entail any physical changes. However, to get the next 150kg and the all important 2240kg new back axle limit some actual mechanical changes were required. Namely, air ride suspension + a tyre upgrade. So a kit for air ride was ordered, and has been fitted. Yes, an appreciable difference in the ride was immediately obvious. No more crashing through rough road imperfections, it just soaked them up, and took roundabouts a bit less like a drunken barge.
Next issue, tyres,simple, upgrade to some 225/70 R15 112/ 110's. Have a look on line and read some forum post, there's loads of choice, right? No wrong. As a precaution, before ordering any tyres I rang a large distributor and left a message outlining my requirements of 1120kg per corner, as it were. I was expecting a succinct email back,with a recommendation. A short while later I took a phone call from the tyre retailer with a few more questions, over weight, type of tyre valve, usage habits. After supplying the answers as best as possible he was able to recommend some tyres, These were the Michelin's .These,
https://www.camskill.co.uk/m27b0s58...Eff_:_C_Wet_Grip:_B_NoiseClass:_2_Noise:_70dB
More importantly, it was the only choice!! No other tyre fitted the 15" Rim size, the loading value requirements 1120kg. and most importantly, the high pressure [ 5.5 bar back 5.0 front.] the coach builder has stipulated in the door shut pillar sticker info. "Ah" I said, "but I've seen lot's of choice for other tyres, some even on your site" . "Yes" he said , "Correct, but they are van tyres, and as such are used differently, and don't run at 75psi, nor are they stood around for weeks on end, and they don't have the same side wall construction to account for a motorhome running at loading capacity on an almost permanent basis"!! He continued " were you to be involved in an accident one of the first things to be checked in a motorhome would be the tyre fitment, and was it correct for a motorhome".
In order to comply and stay legal I will fit initially the back axle with Michelin's and the spare tyre, so as it can be used on any axle. I just wonder how many 15" wheeled 3850kg vans are running on unsuitable tyre's inadvertently as they may not be aware that plain delivery van tyres are not really a suitable replacement for motorhome tyres.
Regards.
Mike.
Regards.
Mike.
