Water tank problems
Chesterfield England Tellus 3
Lunar Roadstar 800
7 years
Well after a weekend away we noticed we had a problem with the water tank
So emptied the garage squirmed under the double floor and found a loose connection for the filler breather pipe and thought that was it.
BUT the under floor was wet so elevate the tank to allow it to start drying out and left it
This morning went back in and found fresh water under the tank but couldn't work out where from so removed the tank set it on our decking on a wood table and put 25L of water in and waited all of 2 minutes before it leaked this time. While I removed the tank I noticed a phone number on the inspection cover - it was a firm not 2 miles away and they made the tank in 2007 !!!! So Traced the firm rang them and asked for advice how to repair the hole, to which they said Hot Air Welding and they would happily repair it for me for around £10
On arrival at the firm they were surprised to find the original label with THEIR part number and who made the tank on the label.
Now waiting for them to ring me to say it's repaired so I can refit it
the damp patch and connection we thought originally was the cause
Rubbish image but area circled has a small hole pierced into the plastic of the seam so the company are going to scrape it clean and refill the area
Well they had the tank for less than 24 hours, they found 2 holes and fixed both of them
So collected the tank and refitted it, now sat with water in making sure I have got all the fittings tight
So we are now back ready to go again starting to load the van with gear not long now
Can you give the firms details please ?
