Water pressure at sink tap (1 Viewer)
Feb 8, 2022
78
209
Fareham, UK
Burstner T620g
Since 2022
Hi everyone hope someone can shed light on a problem we have discovered on our new to us 2014 T620g Travel Van. The water pressure at the sink tap starts off very strong but drops off to nothing after about 30 seconds of being opened, we have a half full fresh water tank, on ehu, 12v on and pump switch on. The shower room tap seems to work reasonably well.
Any suggestions as to why we are experiencing this?
Look forward to hearing from you.
Steve and Jacqui
Lenny HB
53,471
150,165
On the coast in West Sussex
Hymer B678 DL
Sounds like a problem with the microswitch or wiring in the tap.
With the kitchen tap open open one of the other taps shower or washbasin a just enough to make the pump run. If water at the kitchen tap flows ok that's proved it.
The info under you avatar still says you have an Autosleeper.
steveveets
Feb 8, 2022
78
209
Fareham, UK
Burstner T620g
Since 2022
Thanks Lenny I will do that. Thought I'd changed the avatar, mybad, will change asapšŸ‘šŸ˜€
Apr 6, 2019
3,740
7,451
Eye, Peterborough, UK
RV
FourWinds Windsport 6.8L V10
Lennys idea first and then check filter next to pump and see if the very tip of your tap can unscrew as some have a strainer on them.
Feb 16, 2013
19,736
52,043
uttoxeter
ambulance conversion
50 years
Yes we had exactly this and it was the filter in the tap.
steveveets
Feb 8, 2022
78
209
Fareham, UK
Burstner T620g
Since 2022
Thank you Jev88 and chaser, I think it's the microswitch as listening carefully I can hear the pump running when the shower and shower room tap are opened but not the sink tap. Back to the dealers it isšŸ‘
steveveets
Feb 8, 2022
78
209
Fareham, UK
Burstner T620g
Since 2022
Hi Lenny - can't find where I change my "About" info, I can see how to change the avatar picture though, what am I missing??
Lenny HB
53,471
150,165
Hymer B678 DL
Click on your name or avatar in the top blue band then select "Account Details".
