me you and pogo 2
- Aug 16, 2016
- 71
- 21
- Vantage SOL
- ex-caravanner & ex-biker
Hi,
We really need your help !
A class Dethleffs Premium Globetrotter 2002
We have got a leak on the waste water tank, when it is between 3/4 and full the waste water escapes (whilst dump shut off valve is in the closed position) The waste water doesn't escape when it is only half full.
The waste runs out of the tank somewhere, some how and travels across the floor to the wheel arches and drops on to the ground, it also drops waste water in to the spare wheel space which is directly underneath the short blue pipe (we found the leak whilst doing a pre MOT check ourselves)
Access to the tank is extremely limited, there is no inspection hatch, I can't see or find the wiring that goes to the water level meter. I can see and touch the blue exit pipe from the tank that runs to the shut off dump valve, this is dry until it reaches over 3/4 full.
The waste tank is between the two floors and it looks like can't be accessed from above or underneath. One side of the tank looks like it might be behind the wooden panel behind the tape measure but that gap measures only 8" so I can't get in to locker.
What should we do?
Many thanks in advance,
Dave
What should we do?
Dave
