Waste water sensor problems.
Blackpool
Van Conversion
Since 1985
Hi All
I’m having problems with the sensor in waste water tank setting off the full alarm when the tank is empty.What I want to know is can I get to the sensor without taking the under floor tank out.If not is it possible to disconnect the sensor as I don’t really need it.The alarm always seems to go off in the middle of the night most frustrating.My Van is a Swift Rhythm Compact.
Dave
What year?
I think access will be via a large (6 inch) cap on the underside of the tank.
On our Swift Bessie there was a large screw plug in the waste tank
Removing this exposed the level sensor which just needed a wipe with a cleaning cloth.
Assume your tank is underneath the van?
If so there will probably be a large cap on the underside of the tank, remove the cap and there will be about 5 prongs almost directly above it going through the top of the tank. Giving the prongs a good clean should solve the problem. (The prongs might have little rubber sleeves on them, slide them off and clean prong and sleeve, probably best to do one at a time to save mixing them up)
If the prongs feel corroded or caked in limescale you can use a fine wire wool.
Had a look under the van there and no bungs.The tank is fixed with four bolts and brackets which are corroded.Without dropping the tank I don’t think it is possible to get to the sensor and then I might not get access to it.If it is possible to disconnect the sensor that will be the way forward but I have been unable to find a wiring diagram for the camper and on the Sargent web site it does not show my EC400 unit.
I can turn the alarms off, you may be able to do the same until you get the problem fixed.
