- May 5, 2014
- 671
- 169
- C Class
- Beginners, got Doggy the van - March 2014
Yes & yesHas it ever worked ? Have you activated the SIM card ?
Yes & yesHave you ever managed to connect to it. Have you checked settings on the Huawei app?
Thanks. I would like to use the sim in a MiFi, I got iPhone & iPad and Fire stick To connect to the hotspot.Hi the HUAWEI Mifi may locked to a network, where did you get it? or you may need to configure the APN which i had to do when i changed SIM cards in our mifi from 3 to Virgin
VOXI uses the Vodafone network
Here are a few easy to follow steps to make sure you know how to connect your APN Android VOXI phone:
- Open Setting on your Home screen
- Select Wireless and networks or More
- Select Mobile networks > Access point names
- Select the Menu button
- Select New APN
- Enter the following:
- Name: VOXI
- APN: pp.vodafone.co.uk.
- MMSC – http://mms.Vodafone.co.uk/servlets/mms
- MMS Proxy: 212.183.137.12
- MMS Port: 8799
- APN type: If you're given a choice, choose internet+mms, if the keyboard appear, enter*
- Select Menu > Save
- Choose the name we've just created
198.168.8.1 may not work! Mine is end of line .3.1 Need model of router. Another is .1.1Is the MiFi connected to 4G on the router display?
Is the Profile for Dialup set to the correct VOXI profile name in the setup - may need to access via 192.168.8.1 from PC to check.
Hi you will need these settings to connect the Mifi to data network, they are the same when using a phone, just that when you activate the SIM on a phone you normally get or send a text that does this automatically, but sometimes you need to set manually,Thanks. I would like to use the sim in a MiFi, I got iPhone & iPad and Fire stick To connect to the hotspot.
Yes, still no connection to internetIs the MiFi connected to 4G on the router display?
