Motorhomer14
Hi all. I have installed a Orion TR B2B and would like some advice on the settings.
I have an AGM battery. I setup the setting on the pre-set AGM spiral cell setting which will be the following.
Absorption voltage 14.7v
Float Voltage 13.8v
Bulk time limit 10h
re-bulk voltage offset 0.4v
adaptive absorption time on
max absorption time 6h
We run our battery down by 12% which is shown on our capacity gauge. When we was driving at first it was charging all ok then at 91% charge the B2B stopped charging saying the battery was fully charged. Not good as it was not fully charged.
I do not know what setting to change so I changed it to Factory default and it started charging again but factory default states LifePo4
Setting for this are
Absorption voltage 14.2v
Float Voltage 13.5v
Bulk time limit greyed out
re-bulk voltage offset 0.1v
adaptive absorption time off
Fixed absorption time 2h
What should be my ideal setting as at the moment I am not getting 100% charge making this device unusable
Float Voltage 13.8v
Bulk time limit 10h
Float Voltage 13.5v
