Veba AV 70 mm
PPVC Autocruise Alto
I'm a newbie
Hi all I have a problem with the Veba AV 70mm reversing camera system which is fitted to the 2015 Autocruise Alto which I purchased pre lockdown, The camera was working absolutely fine as reverse was engaged camera activated fine, Stupidly I removed the hand held remote control unit from its plastic bag and assumed that the battery could do with changing so tested a new 3v cell battery of same as removed code number and size etc.
And now the monitor activates but no camera picture, I have played with the hand control unit but can not open the menu or find anything other than a grey screen which responds to inputs, very very little in terms of a goggle for finding what I am doing wrong, looks like the company may have folded as phone line is discontinued apparently.
Thoughts please ?
On the link below there is a picture of the user manual for the camera.
It's not much use but I wonder if you have switched the video feed as there appears to be a V1 or V2 button
Mike D I thank you for your reply, and yes I had found the Autosleeper discussion link, the van did come with the same basic instructions included. I need to spend more time on it and hopefully find what I am doing wrong.
