WANTED Tyrepal Solar Valve
Depends which version of solar you have. Solar 4 black/white display has a different size sensor to that of the solar colour. The latter has a larger diameter battery.
Just checked, Tyrepal only sell the larger type sensor now which is backward compatible with the Solar 4. Expensive at £25 each !!!
Presumably you need to specify which one you require RF/LF/RR/LR unless they can be registered - don't know if this is possible with the solar models.
It's the small valve tops. Black/White unit.
