16" were £137 when I bought them less the £20 for two.I'm currently looking at the falkens, Protyre have them at £110 each for 225 70 r15 so maybe more fore r16s. They have £20 off two so £100 each!
My only problem is my local doesn't have stock.![]()
Does anybody know what the max pressure that these Falkens can run at?Another vote for the Falkens & £100 cheaper.
I just ignore the TPMS. It tells me the pressure on starting the engine anyhow, so I can detect a flat before driving.Does anybody know what the max pressure that these Falkens can run at?
I quite fancy them to replace the CP tyres that I currently have. But I have the Fiat TPMS and just incase I can't find a way to get the system setting altered I am thinking (hoping) that maybe a Falken could run at the 4.9 bar that I can get away with on the TPMS.
I'm at 4.4 bar like Lenny on rear, and 4.2 on front (however the wight balance on our van is on rear (more weight on rear tyres).4.9 bar 71 psi is a bit high.
I run mine quite a bit higher than Falkens recomended pressure as that seems low.. I run the front at 52 psi 93.6 bar) axle weight 1630kg and the rears at 64 psi (4.4 bar) axle weight 2240kg.
According to threads I have seen, the psi marking on the side wall is either an American thing, or the maximum pressure during fitting, not the actual recommended running pressure.Can I just ask where on the side wall is the psi and what does anyone who has the falcon tyres say please?
Protyres will probably recommend against the Falkens in favour of the Continental CP tyres, as Motorhomes tend to be at or near full load most of the time,and spend a lot of time standing still so the tyre walls need to be stiffer, and inflated to a higher pressure, which is a different life cycle to a van tyre.I'm currently looking at the falkens, Protyre have them at £110 each for 225 70 r15 so maybe more fore r16s. They have £20 off two so £100 each!
Not in my experience. I changed from CP tyres a while ago and have tried a couple of different C tyre manufacturers.Protyres will probably recommend against the Falkens in favour of the Continental CP tyres, as Motorhomes tend to be at or near full load most of the time,and spend a lot of time standing still so the tyre walls need to be stiffer, and inflated to a higher pressure, which is a different life cycle to a van tyre.
Ok just buying a motorhome which is fitter with Michelin Agilis although dated 2019 and showing cracking (mot advisory) so what replacement? Apparently the Michelin's are not approved for winter mountain use? Shame because I'm a big fan of the Cross Climates on my other vehicles, but the new MH is fully winterised and wouldn't want to rule out winter trips to the continent.
So what would be the best chooses of noise, economy and grip? I see the Falken recommendations which are interesting?
Just go with the Falkens as discussed above. All season, 3PMSF ratedOk just buying a motorhome which is fitter with Michelin Agilis although dated 2019 and showing cracking (mot advisory) so what replacement? Apparently the Michelin's are not approved for winter mountain use? Shame because I'm a big fan of the Cross Climates on my other vehicles, but the new MH is fully winterised and wouldn't want to rule out winter trips to the continent.
