Tyre Pressures ?
pvw10
Gloucester
Coach built
since 2011 after tugging.
Manual says 5.5bar/80psi ish, Tyre wall says 77psi max, tyres look ok and have 60psi in !
What do you run yours at ?
Paul
60 front, 65 rear suits my vehicle.:thumb:
My book says 4.5 bar rear 2.75 bar front.Mercedes Sprinter 3500kg.
Plenty of views on tyre pressures here
Broken Link Removed
Jim
:Smile:
If your manual says that then it is likely that your current tyres are not those fitted by the manufacturer.
Michelin agilis camping go up to 80psi other makes do not
If you know the actual fully laden weight of your axles, just telephone your tyre's manufacturer for the proper inflation pressures. Ignore what it says on the door plate as for some reason they have put the maximum permissable pressure as if its a fully loaded lorry
To get the weights you need to load your van up as if going on holiday and visit your local weigh bridge
I bought one of those in cab tyre pressure monitors that displays the pressure and heat of each tyre. I was amazed at how far the pressure goes up when you are driving for a while. I think I have mine at about 68 psi, and on a long journey they go well above 80 psi. I can't remember exactly. I'll check next time I'm on a trip.
Thanks to all for the replies, sorry for the belated reply as was away in the beast.
60F/65R is what suits mine best (thanks Gooney)
