Truma heater fan issue (1 Viewer)
Silver-Fox
9,266
29,096
Cheltenham Spa
Rapido
im a not so newbie
it seems my woes continue :rolleyes:
The Truma heater fan tries to work, runs a bit slow goes quick the stops.
Truma itself is working fine on hot water or combined water and heating.
The fan spins freely by hand so bearings not an issue.
I’ve done a search on here and google but can’t find any info.
Anyone on here got any pointers as to a fix.
Silver-Fox
Silver-Fox
9,266
29,096
Cheltenham Spa
Rapido
im a not so newbie
I’m not on hook up at the mo so just on gas.
For some reason I presumed the fan worked on 12 V don’t know why.
53,430
149,993
It does.
If it's spining feely and not full of dust and muck it is probably the control circuit on the PCB. I don't think they repir them they just sell you a new PCB for around 300 quid.
Bart
3,188
1,398
Northern Ireland
Boxer L4H2 van build
Since 2016
Yip the fan does go on 12v, but on mine the fan"roars" when it's on gas, once the boiler has heated up, where as on electric it's more lackluster
53,430
149,993
That's because the electric is so low power on full chat it would be blasting cold air round the van.
Silver-Fox
Silver-Fox
9,266
29,096
Cheltenham Spa
Rapido
im a not so newbie
Ahh got you.
Yes it just about gets to the roar and quits grrrr.
Silver-Fox
Silver-Fox
9,266
29,096
Cheltenham Spa
Rapido
im a not so newbie
It does.
Would it still try and run the fan do you think if the circuit is nfg on the pcb
I wonder if I could just fire a supply straight to the fan bypassing the pcb
53,430
149,993
Assuming it's a 12v and only 2 wires going to it, should run at full blast with 12v on it. But if it has more than 2 wires it may have internal control circuits then not wise to.
Silver-Fox
Silver-Fox
9,266
29,096
Cheltenham Spa
Rapido
im a not so newbie
I’ll have mooch around it tommorow and see what’s what.
Then it will be the fridges turn as that’s not firing up at first asking.
Still no one said motorhoming was cheap or easy :rolleyes::)
Silver-Fox
Silver-Fox
9,266
29,096
Cheltenham Spa
Rapido
im a not so newbie
That’s a good start it’s absolutely p****** down at the mo so the fan can wait a while :rolleyes:
Feb 5, 2014
1,699
3,988
mid-Norfolk
since 2006
Silly question: it's not the thermostat set low so that the fan cuts out is it?
Mine works happily 95% of the time but SOMETIMES it refuses to throw out hot air, even though the thermostat APPEARS to be reasonably high. I turn it down then turn it back up and "woosh".
[Much cheaper than a new pcb!]
Good luck - Gordon
Silver-Fox
Silver-Fox
9,266
29,096
Cheltenham Spa
Rapido
im a not so newbie
Good luck - Gordon
I tried turning the boiler stat for the heating up and down but it made no difference :rolleyes:
I much prefer problems where spanner’s are involved.
Elaetric/electronics I find a pain in the rump :mad:
Thanks for the suggestion though (y)
Feb 15, 2016
638
1,066
Since April 2016
Are you using it on auto or manual? You should be able to control the speed on manual whereas on auto it will decide what it wants to do.
We currently have a different problem with ours, on electric the thermostat doesn't work, I believe this is likely to be down to the control panel as well :(
Silver-Fox
Silver-Fox
9,266
29,096
Cheltenham Spa
Rapido
im a not so newbie
This is the only controls I have.
It’s an older system and no separate controller for fan speed.
I’ve just turned the system off and the fan went into cool down mode.
This blows hot air through the heating tubes.
So the fan definitely works.
Unfortunately they have fitted the boiler in such a way you can’t get the top of the electrical box off :rolleyes:
Bob Morrison
23
27
Compass Avantgarde 130
5 years
I've actually got the fan off mine at the moment investigating a problem which appears to be that when the casing/frame of the motor gets hot something expands enough to stall the motor as if something expands so much that it doesn't want to turn freely any more.
Silver-Fox
Silver-Fox
9,266
29,096
Cheltenham Spa
Rapido
im a not so newbie
Yes you can, you just have to dismantle the van first. :rofl:
Thanks @Lenny HB I knew I could rely on you :rolleyes:
Mines turning freely even when the boiler is too hot to touch.
And it runs a cool down when turned off and hot.
This is doing my nut in :mad:
Aug 31, 2009
148
162
Near Long Stratton, Norfolk
Carthago C line
25+ years
Our Truma combi 6 is doing the same thing. As soon as the heater fan moves up into "turbo" mode it cuts out. If we heat the water first then switch to water and heat it gets up to temperature OK, but if we then turn the water off it goes into cool down mood for a few minutes but the heater will then stay on. Our local Truma engineer is going to look at it when we get home, he thinks it could be an overheat sensor causing the problem. This is on gas only by the way, it works OK on just 220V.
Silver-Fox
Silver-Fox
9,266
29,096
Cheltenham Spa
Rapido
im a not so newbie
Will be interesting to find out what fixes it.
Would appreciate you posting the outcome.
browning22
5
rimor koala 722
Hi silver fox, I currently have this exact issue. Are you able to advise if you found the issue in the end?
