RichardandKaren
I am having problems with my Truma boiler with white smoke ( steam) coming out of the side mounted external exhaust flue and also water dripping out of the flue. I phoned Truma up yesterday and they suggest it may be a flue blockage or ducting problem. Having opened up the external locker to the boiler and put my hand on the black ducting that goes to the flue, and given it a shake, I think they may be right as it is very rattly. I suspect that maybe the inner steel core ( which I believe goes to the exhaust part of the external flue) may have come loose so that the inlet and exhaust air supplies are getting mixed up in the pipe. To my mind, this might explain the white steam and dripping water?
So, I need to access the pipe and check its connection to the flue. It's going to be very tight to do that from inside the van ( 2004 Rapido 786) and may involve me in some cabinet disassembly. But I guess it will be doable. My question though is, can this be done from outside of the van? I cannot do it via the locker as it's just not possible to get your hand round to the inside of the flue. But, can you undo the flue from the outside and pull it away from the van wall with the pipe still attached and then inspect and fix from there or is the hole in the van wall too small for the pipe to fit through anyway? If anyone knows then I'd appreciate the help as I just want to try and do this the easiest way possible!
