Hi we seem to struggle with getting enough hot water for a shower. Ok for a bowl for washing up but that’s it. Any ideas or tips?
Hi we have 10L boiler, we can get hot but not much. Do we have to wait for the symbols on the control panel to completely stop flashing? Tried on boost gas and electric.I am a little puzzled at your lack of hot water. It does of course depend on the size of the hot water storage unit but providing the water is hot, very hot, the mix of hot and cold water should allow a couple of showers. Perhaps you are not allowing the water to get hot enough.
On all 3 Hymer's we have had never bothered with the electric option, €450 pays for an awful lot of ga., also we rarely use an EHU so no point.I think the electric heating elements are only seen as an option by some continental manufacturers because 16A supplies are not taken for granted in other countries. Carthago is not alone, it was only an option when I looked at Hymer.
The only difference between HOT & BOOST is HOT heats the water to 60°c, BOOST heats the water to 62°c and turns off the heating until the water is up to temperature. What you are saying can't happen.When I want hot water I select the HOT option and it gives me plenty of hot water but if I select BOOST it only gives me a small amount ie a bowl full
6KW on gas, also if you use Gas & Electric you only get 5.8KW.The Truma heats up much quicker on gas than just electric. From memory with both elements on the electric is only 1.8Kw whereas the gas is much more powerful.
You only need 8 amps but you get so little heat not worth the bother.All these boilers are basically gas boilers with an electric add-on as an afterthought. On those occassions I have EHU I leave the boiler on 24/7 as it takes ages to heat up on electricity or just run on gas where it works far better. As mentioned before 16A ehu is rare except in the UK.
Always set it, most manufacturers fit the temperature sensor above the door often above head height. This often results the heating turning off before the main seating area is at the required temperature. By setting up the offset you can compensate for this.Question, do any of you understand or see the point of using the thermostat OFFSET facility?
Had two vans, never bothered with it myself.
As others have said, nearly all European models sold into the European market have gas only heaters fitted, and many do not even offer electric as an option. That is because few sites in Europe have the 16A supplies we have as standard in most of the UK.Interesting replies thus far, I need to try boiler on Electric 16amp hook up to see how poor it really is at getting the van warm in cold conditions, we have only used it on gas thus far as we are either wilding or on a field rally, usualy with no EHU.
Hence why we used a full 11KG Gaslow tank over 5/6 days a couple of weeks back, heating was on 24/7, showers every day, bloody freezing and heavy rain & winds, but it was south wales
I have heard many others say that their boiler is very poor at heating on electric, so it must be a well known fact by the manufacturers.
Les
Yes Carthago are exactly the same as Hymer I guess in that they have "option Packs" some of which are needed to have a usable van, so the basic price quoted should be taken with a pinch of salt, take it, then add 10K should get you near the price you have to pay (before any discounts etc)As others have said, nearly all European models sold into the European market have gas only heaters fitted, and many do not even offer electric as an option. That is because few sites in Europe have the 16A supplies we have as standard in most of the UK.
British built vans, and many European vans destined for the UK market usually have electric as well as gas as standard. Other European makers, such as Hymer, offer it is an option and often as part of a discounted "Option Package".
The Alde heater we now have has options to use 1KW, 2KW or 3KW settings for the electric heating. You can also choose to have both gas and electric heating on and can choose which takes priority. We invariably use gas only to start with and only put the electric on (if we are on EHU) once the heating has reached its set temperature. Never used more than the 2KW setting.
Not sure, it’s brand new so could be an issueI am just wondering if there is possibly a thermostat in the system preventing or limiting the water temperature from being hot enough to dilute with cold water.
This seems to be the solution then! It cannot heat up quickly I now realise and electric is basically just ticking it along.Never had a problem getting two showers out of our C6.
The only problem we have with the current Combi's is you can't use the ECO/40°c setting if two people want a shower (it was fine on the older C6002). The problem is thermostat used on the ECO setting has a very wide hysteresis, it turns off when the water reaches 40°c but does not turn back on until the water temperature drops to 27°c IMO makes the ECO setting useless and we use more gas as we have to use the HOT/60°c setting which is hotter than we need.
Also the C6 takes far longer to heat the water than Truma claim. Set to HOT or BOOST it takes 40 - 45 min to get up to temp, set to Heating and HOT takes at least an hour. If you just use heating the water takes well over 1½ hours to get fully hot.
To have hot water for a shower and get up in a warm van we set the water on BOOST to come on ¾hour before we need heating.
e.g. Set the timer to turn on at 7 am with water set to BOOST & Heating to 18°c. The boiler will fire up at 7 am and once the water is up to temp the heating will turn on at about 7:40 am.
