sako
- May 1, 2021
- 2
- 0
- coachbuilt
Truma combi 4e (2017). When using gas only I get an error message when I turn the heating temperature down on the control panel, the boiler makes a ‘click’ and the fans slow down. I then get an E 202 H. This error message will not clear and the entire system has to be turned off and restarted. I can then start the heating again on gas.
The gas pressure is normal and the boiler will operate with all the cooker burners lit as well as the fridge.
If I turn the control to electric or mixed when I am not connected to electric supply I get a W 45 H message which clears as soon as I switch back to gas only. In fact all error messages clear when the error is rectified except the 202 message.
I do not believe it is a gas pressure issue because the boiler works perfectly on gas until it shuts down so Is this a fault with the PCB in the boiler?
