The twist is that when opened only about a litre of water drains out. Tend to go away for a few days every other week and at this time of year drain down between trips. First noticed when on refilling the system came up to pressure in seconds rather than the wait for filling the boiler, a Truma combi. Next drain down put a bucket under, open valve and about a litre came out. About 10 minutes later the rest suddenly drained. This time again about a litre but it’s been left open for a day and no more water has come out. If I turn the pump on it pumps water out but stops when pump is turned off. Taps are opened as usual. Think I might change to a manual dump valve but is the problem likely to be in the boiler?
