- Jun 20, 2022
- 1,078
- 1,986
- Just looking
Just put 4 new TPMS valves from schrader into my daughter’s tyres and they are exactly like normal rubber tyre vales, though you can get the steel bolted types as well,
Any tyre depot will do a quick scan to see if they are active and Shows battery condition and
What happens if they are not active? Just thinking I could do without if necessary. I'm old school, check tyre press on a regular basis.
is it possible the dash warning may have been deactivated?If they aren't active it should show a fault on the dash.
Does light come on when ignition turned on?is it possible the dash warning may have been deactivated?
Happy Jack.
Will check that out now and get back.Does light come on when ignition turned on?
Will do when I'm ready (soon) for new wheels/tyres.Yes but unlikely, if over 5 years the batteries can give up the ghost so get constant warnings, and if people can’t be bothered to replace the TPMS sensor, then they might disable the monitoring unit,
Just take it too a decent tyre depot and it will take seconds to interrogate the Valve one way or the other,
Van is Feb 2016 so is 7 and a bit years old.
Just checked, light does not come on! Guess it's not an MOTDoes light come on when ignition turned on?
Not sure, I know if the light stays on it is, but I might be corrected.Just checked, light does not come on! Guess it's not an MOT
failure.
Never noticed it until now. Had the van 3 years now and been through 2 MOTs, either the light has always been unlit or bulb has popped a long time ago or at some time between when I got it and now.Not sure, I know if the light stays on it is, but I might be corrected.
Would mine still have the warning light on the dashboard and as part of standard build but not in use perhaps?Our 2016 Fiat Ducato (A Class) doesn’t have TPS.
We have since fitted a Tyrepal set up which is great.
Ok, thanks.Sorry Happy Jack I cannot answer your question. I will check on ours when I bring it home later in the week.
Had it got a dash light for tps, but obviously not in use?Mines a 2018 and doesn’t have factory fitted TPS
Yes, I alluded to that in an earlier post. Did think standard build would have all the possibilities but not all in use. Depends on the spec.The dashboard will have the light fitted regardless of TPMS units in the wheels as it is an optional extra. It is just switched off in the software for your van. Would be ridiculous to make different dashboards for each option
Yes, I did exactly the same for the last 2 years with the van but now that I'm getting ready for new wheels/tyres I would like to know. Will be going to a local wheel and tyre specialist soon and will get them to check but I'm beginning to believe that my van hasn't got tps.You get so may lights come on at the start, I don't pay them much attention just so long as they all go out
Ok, if that's what happened to my van before I got it I can live with it.Many options can be switched on/off with multiecuscan via the OBD port
As long as no signs of cracking as that's usually the reason people change them, mine were starting to crack with 8500miles done with 5-6mm tread but had a date stamp of 2018 on a 69 plate so always check date stamp, so mine were on the van from newOne other thought, this time on tyres.
We do 4K miles each year in the van.
Think I've read in various post that 4 years is approx right for renewing tyres!
That would be 16K miles for mine.
Would definitely leave them longer if still plenty tread left.
Happy Jack.
Yes, will do that.As long as no signs of cracking as that's usually the reason people change them, mine were starting to crack with 8500miles done with 5-6mm tread but had a date stamp of 2018 on a 69 plate so always check date stamp, so mine were on the van from new![]()
Yes, will do that.
What typical date will there be on new tyres!
Happy Jack.
Can be within 12 months dependent on stock but best to check as can be older?Yes, will do that.
Happy Jack.
