Adrian140974
I am thinking about towing a car with a braked trailer but not done before. Our motorhome is 9m already so would be very long. Any advice or experience from others? Thanks
That's great thanks. I just thought I would unload the car and be able to push the trailer but I might be being a bit optimisticI towed a Brian James single axle trailer behind my Winnebago for 10 years of so, only problem was a couple of burst tyres.
As tacr2man say moving an unloaded trailer can be hard, on tarmac its easy, but on rough grass it gets a lot harder especially a twin axle.
Can't say I ever bothered about balance or nose weight, as the car fitted on the trailer and there wasn't much you could do to alter its position, besides a 1300kg trailer wasn't going to affect a 9000kg RV much.
I fitted a towbar to the car so it could tow the trailer around site if needed.
Ahh right did not think of that, thank youIt’s easy to to manually manoeuvre a twin axle trailer if you wind the jockey wheel up so that only 2 wheels are on the ground.
Ouch I won't ask but helpful advice thank youI tow a car with my 7.9m Autotrail Delawar. My advice if you do tow, don’t try to reverse. Very small distance from tow bar to car wheels equals a pain in the a***. Don’t ask me how I know![]()
Most definately yes with the battery in a box on the trailer. Highbridge have a demonstator of the motormover on a trailer.Can a trailer be fitted with a motormover?
That sounded like fun, thanksReversing isn't easy but if you take your time its doable. My RV is 30' and I managed to reverse that with the car trailer down between two artics late at night on a lorry park, did take me a couple of goes though.![]()
Excellent thank you, I will have a lookMost definately yes with the battery in a box on the trailer. Highbridge have a demonstator of the motormover on a trailer.
I actually looked into this with my local dealer and he told me that due to the sensitive electronics it wasn’t a particularly good idea, fyi we have a trailer box fitted to the a frame but by the time you fitted the battery which needs to be a minimum 110 amp hour then the electronic gubbins there wouldn’t be much room left. Also if the electronics are not in a waterproof environment your warranty will be invalidated. I will watch your thread with interest though, maybe you will find a way, I hope that you do.Can a trailer be fitted with a motormover?
Thank you, really good points madeI actually looked into this with my local dealer and he told me that due to the sensitive electronics it wasn’t a particularly good idea, fyi we have a trailer box fitted to the a frame but by the time you fitted the battery which needs to be a minimum 110 amp hour then the electronic gubbins there wouldn’t be much room left. Also if the electronics are not in a waterproof environment your warranty will be invalidated. I will watch your thread with interest though, maybe you will find a way, I hope that you do.
HiThank you. Yeah it's OK upto 1600kg according to the log book. I think that is correct? Appreciate the advice. A
Thank you for all these really helpful comments. I will be towing a Fiat 500 with a kerb right of 930kg, the trailer I am looking at is 495kg for twin axle and 400kg for single axle. I will double check the plate on the van before purchase - thanks. Tow bar is a Wiko and looks great plus our motorhome has had the upgraded payload installed. Unfortunately I am old enough to tow as licence was granted before 1997 lol. The trailer can be loaded unhitched etc so useful to know that helps. We plan to store the trailer with car on at the storage yard that we keep the motorhome and I agree security locks are a must. Appreciate all your advice. ThanksHi
1600kg is not huge and you need to confirm that figure from the Swift weight sticker.
What car are you looking to load onto the trailer and how heavy is it?
Be mindful of your motorhome axle weights, if you run near the maximum gross, then a trailer could push you over the edge, especially on the third axle.
Tandem axle trailers can also be quite heavy and a mover plus traction battery would add another 50-60kg. I used a single axle Brian James for a Smart Car and that was easy to move by hand once the Smart was offloaded.
Regarding nose weight and balance, I tried loading forwards and backwards and found the ideal with the Smart (engine at the rear) was to reverse on. I marked the ideal position, so it was easy to get it right first time, every time. Get it wrong and you risk instability such as snaking.
Do you have somewhere to store the trailer when not in use?
Some but not all trailers can be loaded/unloaded when uncoupled from tow vehicle. This can be useful on site, by allowing you to unhitch complete before positioning motorhome on pitch.
Does your driver's licence cover you to tow?
Is there a suitable tow bar available for your motorhome?
Don't forget security for the trailer, you would need this before going off site in the car for the day.
Just a few things to consider and confirm. Good luck.
Geoff
That's a good idea, would still need a battery box I guess. Thanks
Looking at it we will be 9m motirhome plus 5m trailer.... Will be very long! CheersImported a Honda vamos, got it all ready and decided to sell it.
We would have been almost 9M. Plus a trailer plus a car when we turned up at sites.
Similar to what we were, towed around UK and to Portugal several times.Looking at it we will be 9m motirhome plus 5m trailer.... Will be very long! Cheers
Thanks, are the A frames expensive? Much work required to the car? CheersSimilar to what we were, towed around UK and to Portugal several times.
Now use an A frame in uk and hire a car abroad.
That's great thanks, I will have a lookYou can buy A frame kits to fit yourself from several companies or they will convert your own car.
Cost is around £2000 I believe for them to do the conversion.
I did my own as wife's Alto isn't popular enough for anyone to make a kit
