I understand that you cannot tow, unsuspended, a petrol/diesel automatic car. Is the same true for an electric car please?
And remember the weight of EV'sThanks. A trailer it will be then
Tow limit Bolero 2000KG ? some as low as 1340kgAnd remember the weight of EV's
Because they do not have a 'proper' neutral gear you should not flat tow an EV.
Only legal for recovery.I assume you could tow a automatic is you had 2 wheels off the ground (the driven ones in the case of a 2 wheel drive) using one of those 2 wheel trailers that recovery companies sometimes use?
I assume you could tow a automatic is you had 2 wheels off the ground (the driven ones in the case of a 2 wheel drive) using one of those 2 wheel trailers (dollies) that recovery companies sometimes use?
The same presumably for an EV if it was a 2 wheel drive EV?
Not seen anyone use these on motorhomes though - are they not legal? Would have thought they were as safe if not more so than a 'toad'.
Can suspend tow backwards...steering has to be "locked" straight aheadI wondered the same and I guess if the driven wheels are off the ground it would be possible.
But then some EVs are RWD so you would have to tow it backwards which wouldn't work.
It’s simpler than thatIn UK law, the car being towed can be classed as a trailer - nothing more complicated than that. However as the trailer (towed car) will not be using it's brakes, it is classed as an 'unbraked trailer'. The legal limit for weight of an unbraked trailer is 750kg.
If the car been towed is greater than 750kg the "trailer" requires its own braking system. (hence why toad cars utilise the cars own braking system by electronic system)
If using a dolly system over 750kg with 2 wheels of the car are on still on road surface, therefore the 'car+dolly' doesn't meet the rules for a braked trailer (all wheels must be braked).
The acception to braked trailer rule is, for recovery purposes only.
You can tow any car to repairing garage, safe location with unbraked trailer but this must conform to towing ability of vehicle and train weight. (not towing range rover with a transit van as towing capicity of van is around 2000kg and range rover is 3000kg)
That is true for a car with a torque converter automatic box. However, there are a few automatics classed as semi-automatic or robotised manual, or more accurately automated manuals. In the small car range they would be the Toyita Aygo, Peugeot 108, Citroen C1 (all from the same factory), the small Smart car and the Fiat 500. There are other vehicles that are automated manuals, but you have to be careful between 'wet' and 'dry' gearboxes.I understand that you cannot tow, unsuspended, a petrol/diesel automatic car.
Interesting.Is it the same rules in EU? (I know toads aren't allowed over there, although some may argue differently)Only legal for recovery.
