Tow bar electrics
BikerGraham
Newcastle upon Tyne, UK
Autograph 75-2
camping and caravanning since a kid. New to motorhomes
Afternoon folks.
I always thought that a modern motorhome needed van specific electrics when having a tow bar fitted.
Just had a quote from Hedley’ in Durham who have an excellent reputation.
They said that for my van, Bailey autograph 2017 based on the Peugeot boxer. There is no advantage to having the van specific electrics installed, over the standard electrics for 13 pin socket.
There is a £300 cost saving.
Would appreciate peoples thoughts on this please
Graham
13 pin electric socket replaced the old 7pin socket. I'm sure hedleys would ensure you have lights/brakelights, reverse light etc everything that your van rear displays. I think the more expensive option is for a car towing a caravan where electric is required for fridge ?? Sounds good to me, A19 caravans also do towbars I believe maybe get another quote if unsure.
Thanks mate.
Yep reckon your correct they are not going to fit anything that isnt.
I gave them all the van details and reg number so, they have all the correct information and they do have a sterling reputation. I know a few people would not go anywhere else.
I was just surprised when they said there is snow advantage with my vehicle to have the dedicated electrics installed. Maybe it’s that others see that as just addding money and profit to a job and Hedley’s see value for money as more important.
Maybe only relevant if your towing a caravan
We had a bar and electrics fitted to a 2021 van. With Swift the tow bar electrics just go into the garage and plug into the board in the back, no fiddling about just straight in. I would say they are 13 pin and the actual socket has a micro switch on it the disables the reversing sensors when a trailer etc is connected. If a tow bar is fitted then both the electrics and bar will be looked at and tested in an MOT. S always worth thinking about.
Have a feeling you’re right with that. So irrelevant for a motorhome towing a trailer.
Whereas the Peugeot boxer van towing a caravan would need dedicated.
Thanks for your comments 👍👍
Think decision made. Their price is £900 for swan neck bar and 13 pin electrics. So ok with that .👍👍
Electric stability as in a caravan? I doubt an A frame has an electric stabiliser.
Van specific harness should show up any bulb failures on the dash, generic may not?
I’ve been towing boats, caravans etc. for over 60 years (gulp). Any wiring utilising Scotch connectors are usually very troublesome in my long experience, don’t let them even think of using them!
Totally agree, the one fitted to mine has a sergent loom that fits straight into their connector, no messing about. There is also a function that stops the fog lights coming on on the MOHO if you are towing a trailer. Basically it prevent fog lights on the MOHO and the trailer being on together, this apparently is not allowed.
Afternoon folks.
Graham
i recently had towbar electrics fitted for my cycle rack, i was also offered the option and it was explained to me that the only difference was cost .... apparently they make up their own 'looms' as they go along, just using cable off a roll. i chose to save over £100 .....
i also understand that scotch loc type connectors are not used by professionals, they solder any connections that need soldering and also make up their own wiring harness with the proper connectors.
i used a towbar specialist company in Braintree essex
Ours has a 13 pin as we tow a car with electric braking from memory pin 9 has a feed to top up the battery of the car while being towed👍
If it has canbus on the towing vehicle then it usually needs a canbus relay to stop spurious fault lights on the dash . Mine is 2007 Transit & had one fitted with towbar in 2019. cost additional 80€.
It packed up in the UK last year so I got a replacement off amazon for about 25 quid.
I think here when dealing with Henleys if you ask what lights your going to have etc they will give you the truth.
Sounds like they will be using a bypass relay. This takes the small voltage signal from the canbus on the tow van and triggers the 12v supply to the relevent lights on the trailer. Prevents errors on the dash for lights not working. They're fine unless you have reversing sensors and other paraphernalia to confuse things
