Kool Kroozer
- Apr 19, 2014
- 1,361
- 2,228
- Low Profile Hobby Premium
- Always learning
Am wondering if any of the wise ones on here are able to shed any light on this problem i am having with our electric step : It retracts as it should when engine starts but the problem being is : it also retracts any other time too, sometimes in small stages, it can be fully extended and within a couple of minutes it can be halfway back in the housing, an before you can look again its fully retracted back in, i have took it apart about a month ago but nothing changed, then today i really took it apart
and discovered that when the step is fully out - if you just flick this switch (white in the pic) down the step starts to retract in (but only in incriminents) obviously the more you touch this ( fridge door light switch ) the more it retracts in.
But even when messing with the step while its been unbolted from the van - but still connected to a live feed - i can hear the relay in the fuse box where the fuse is for this step keep making a clicking sound - even if i remove the fuse for the step the clicking continues... Anyone have any idea or similar problem of what is failing ?
