Thetford N80 fridge
Bristol
Weinsberg
A few years.
Having a pcb failure on my Dometic fridge I bought a reclaimed Thetford N80.
I now have a fridge that runs on 240, 12v circuit fires up, but not working on gas. It has a combined thermostat and igniter switch which turns as it should and push in for the piezo ignitor, which produces nothing no clicks. At the back of the fridge there is a black box with a single lead that goes to the igniter by the burner. There are no other wires so how does it know when the switch is pushed in.
I guess that there should be a connection between the two? Thetford wiring diagrams are not much help, nor is any lead listed in the spares.
Any knowledge most welcome.
Well blow me down, Thetford help came through. The leads are at the bottom of the fridge and unless you knoe you can't see them. Reconnected and works fine. Happier Easter Bunny.
