Thetford Fridge N90
Isle Of Man
4 years
Need some help please, I think I have fried my Thetford power board its the N90 version manual, there is not power at all and have checked all fuses including the internals on the board using a multi-meter.
Any suggestions as where to take it, to get a replacement power board.
Steve.
Leisure shop direct should be able to supply what you need
Is your board receiving power OK when you check with your multimeter?
Bart Thanks Bart I only tested up to the 12v plug connector and likewise the 240 vac plug connector under the Power board but not actually undone the power board housing and tested there?
Check the power is reaching the fridge first, we had daft issues with one of our MH fridges and after further investigation it was an issue with where the fridge power lead was connected to the 'socket' at the electrobloc, it wasn't fiting tightly, once this was sorted there wasn't an issue.
Also make sure the fridge is getting a neutral supply OK as well as a positive supply. Using your multimeter
