Friends have just got a '14 plate Bailey Autograph. At the Chester rally, their toilet stopped flushing. We checked the 5 amp fuse at the distribution unit and this was ok. Checked that we were getting 12 volts at the supply connector in the cassette bay and then moved on to the push button on top of the cistern/flush tank. I peeled back the foil cover and prized out the circuit board which looked fine and was getting 12 volts at the push on connector. Next we unscrewed the access panel and withdrew the flush pump and manually rotated the impellor which seemed ok. I got a couple of jumper wires and took the feed from the edge connector to the pump and it worked fine. The edge connectors have 6 wires on them, 2 are the supply in, 2 are the feed to the pump and 2 disappear down into the toilet to who knows what (level switch, solenoid) ? I was wondering if the circuit board/ push button was faulty, or whatever's at the end of the two spare wires is having a detrimental effect. I've included a pic of the circuit board, looks complicated for what should just be an on/off switch, excluding whatever's at the end of the other two wires ?
