Tesco PAYG sim with Rocket Pack
Dumfries and Galloway
Pilote&Coachman C.vn
Got the above sim and preloaded it with 100gb on the £30 a month rolling contract
It works fine on my old IPHONE XR and connects to the internet
Tried it in my Huawei router E5785 and changed the APN settings and the screen says O2 and a good 4G signal but dammed if it will connect to the internet
Im stumped
That sounds expensive if you are paying £30 for 100gb unless I’ve read it wrong, I have a Smarty sim in the van HUAWEI and when I need it I pay £20 for a month of unlimited.
Unfortunately the Tesco sim is "not supported" in mifi routers. Some get it to work, some don't.
Just leave it in the phone and use it as a hotspot, I use my iPhone X in Spain with a Tesco sim in it, as it’s an old contract I just pay £22 extra a month for unlimited and connect the iPads to it.
Tesco has no roaming charges so you can use the 100gb each month abroad
I may have to do that , it was really for watching live TV in the evenings
Yes, I have an older Tesco sim (O2 provider) too with unlimited data, calls and texts at £17.50/month Unlimited Roaming in EU without any charges. I hotspot my Smart TV and Firestick, and for last 3 years have used it in 8 countries - eating loads of data without an issue.
I pay £10 a month unlimited data in Europe with Tesco 😉
Yes that’s why I change my tariff to unlimited for the 3 months that we are there, but the post does not say anything about using abroad and £30 for 100 gb is expensive.
I thought Smarty had a fair usage policy
This is incorrect, there is at least one Huawei mifi in Tesco's compatible devices list and I have two Huawei mifi's that are not on the list but both work fine, one is an E5873. Check that the sim is correctly seated and check that the APN has not defaulted back to an O2 one.
If you look there are a couple of threads which mention this problem. I had all sorts of issues with Tesco and mifi unit. Was eventually refunded by Tesco as accepted it wouldn’t work in my WiFi and had been assured it would. Have a second mifi unit as the one on their web site but was so fed up by this time I went with iD mobile and lebrara.
sim is definitely seated correctly
With my phone connected to the Mi-Fi via the Huawei app its showing as Tesco
It worked in my phone. When it didn’t work in mifi unit the first agent said I had a faulty sim. Stopped first one immediately and would send another! Week without then second arrived absolutely no difference. Had so many reasons/excuses from Tesco I gave up. Basically I think if you have changed all the APN s etc and rebooted everything and it still doesn’t work then it’s not going to. Some have been lucky. I wasn’t one of them.
Use in anything other than a phone handset or tablet is against the Tesco fair use T&Cs 3, xii
So you may get lucky that it works but for some, like me and a Huawei, it didn't.
Does the sim work in a phone?
Here's the support page for a Huawei mifi there are some suggestions if it won't connect to the Internet.
It works fine in my old iPhone XR
Didn't even need to change any settings
If mifi's are not allowed why is one in the compatible devices list?
No idea. I just know when it wouldn't work for me a UK call centre agent, after previous overseas agents, told me some did some didn't and that was that.
Works perfectly in my ZTE MU5002 Mifi and it's a PAYG Tesco sim. 35 GB EU use as well. Set it up in my smartphone, then transferred to Mifi to set APN .
We've had this discussion previously on here.
Looking at the wording of the T&C's I think they are referring to static home routers with an unlimited SIM. Not a mobile router. Anyway. How would they know that you're using a router not a smartphone?
I would be very surprised if the device, logging onto the mobile network, as part of the sim handshake process, does not have to send some form of identity to the network. If nothing else your provider knows the device IMEI and can block those for theft, so I suspect the IMEI will also identify your device type/manufacturer/model.
Something else peculiar to Tesco Sims is that they turn off the hotspot. In my new phone it constantly disconnects, old phone no problem and I know it is not the phone as at the moment I am running a Digimobile SIM which operates on the same network Movistar or O2 and it never disconnects. This is at home or abroad.
