Table fitting
Jul 30, 2016
67
162
Warrington
a class
6 years
I am thinking of changing the table fitting in my Autotrail 2015 Apache 632. I want to change it to the usual caravan single leg fitting attached to the wooden floor panel just behind the front seats which goes across the floor. I want to use a recessed fitting which is removable. Does anyone know what is underneath this panel?
Hi juggler. Not sure if your floor construction is the same as my 2003 Cheyenne but I'm guessing it's the usual sandwich. AT direct would-be able to tell you. Alternatively, if you are talking about the fiamma recessed "hole"you could contemplate using one of their tripod stands. It's does not add much to the height and means you can use the table anywhere, even outside. I have one for the table we had in the old Bongo. One of the best little extras we bought.
Hope you get an answer to your original query.
Cush
