Swift Bolero 714SB Fresh water discharge tap set up missing
Durham, UK
Swift Bolero 714SB
Since 2018
Hi and a big thanks for previous help, and Happy new year
I got the swift bolero 2015, and discovered the pipe out system is missing, the supplier is a complete waste of time, and to far, there is a stop tap and drop down mechanism to pull down, a straight pipe seems to turn the main tank tap, any ideas or photos will be appreciated
Jeff
Do not know if it is the same but a Swift Bessacarr I used to own had a flap in the floor that allowed access into the top of the fresh water tank and you had to pull out a plug from the inside of the fresh water tank to drain it.
My dump valve is just a small valve wheel below a hatch in the floor. It just drops the fresh water directly out the middle of the tank on to the floor under the van. There's no pipework.
