deleted79651
- Mar 9, 2021
- 2,279
- 6,142
We had a lithium battery fitted about a month ago and it's been brilliant. I don't think it has fallen below 95% Charge level and it has yet to complete its first discharge cycle [think it's guaranteed for 500 cycles!], even in the evening when the drop down bed is used plus LEDs, phone chargers and Elaine tries to test the water pump to destruction! The downside of the latter activity is frequent disposal of grey water and daily topping up of the fresh water tank, something I am reluctant to do by driving Brunhilde for, say, 50 metres from cold, to refill.
I have a spare 19 litre pm Reich submersible pump from caravaning, after the Whale predecessor failed whilst we were in Spain, and I wondered about the feasibility/safety of using the lithium battery surplus capacity to pump the water top up from the existing 25 litre Jerry Can [usually fill it to around 12 litres and then lift it to pour slowly down a Chinese Shop Spanish funnel and hose attachment to the inboard tank]; this leads to a sore right shoulder and some lower back discomfort, hence the brainwave about using a pump. I'm just not sure how to go about the work. There is insufficient space in the water tank filling cupboard to site a power supply, either from the external access or from inside the Van [which would involve removing seat swabs, seat backs, plywood supports et al in a 5.99m Van that struggles to replicate a furniture repository!
The Lithium Battery is also under the seating, so I was thinking about perhaps using the 12v TV socket, which only gathers dust since we don't carry a telly, and up to 5m of cable attached to a Hellla or cigarette lighter connector at the TV end, and a Wago block connector or similar in a jointing box to connect the pump via the kitchen window. It won't be the most elegant solution, but it will be used once each day for about 5 minutes, including walking to/from the water tap. Then the cable can be stored in the external locker with the water carrier and all the other clobber.
There is a commercial kit available at £55 Water Pump Connecting Kit, but this includes another pump that I don't need! The cigarette lighter connection looks really neat though! As usual, I confess to being a complete numpty in matters electrical, so would appreciate any advice or suggestions [in words of 1 syllable, e.g. 'connect the 2 red cables ...'] to help me with this task.
TIA
Steve
TIA
Steve
