Supplement battery charging (1 Viewer)
Top Hat
375
623
Durham
Van Conversion
8years
My Sargent unit ehu battery charger is only 150w and I have 300a/h of batteries, all of my trips will be in the summer months mostly abroad so will rely on my 220w solar a lot off grid, which got me thinking if I needed ehu with no solar being produced is there any reason why I could not help the battery charging with my Ring 8amp battery charger straight to the leisure batterys from the vans 230v side.
grahammay2
35
5
Eastbourne East Sussex
C Class,
Since July 2010
If my Sargent is also that low it would help explain why I've been very unhappy with the charging.
Ec480 & ec500 fitted to Auto-sleeper Broadway 2013. Anyone else have issues?
Graham May
DBK
18,454
50,103
Plympton, Devon
PVC, Murvi Morocco
Your 150W will be more than enough as it will run 24 hours a day. You won't get anything like 220W from your solar apart from a few hours around midday. :)
Whether you can cope on solar alone depends entirely on how much power you need. Unless you have an inverter fitted and plan on running things like microwaves for longish periods I would think you will be fine. I suggest see how you get on but by all means take the charger but I don't think you'll need it. :)
tonka
11,035
22,164
Cannock, Staffs
A class Burstner 800
Since 2000
Graham May
300watts on the EC500 (y) Just read it on the Sargent website.
No issue on mine (2012 Apache 700) seems to charge fine.. 2 x 110amp leisure.
Dec 6, 2011
12,199
27,282
South Wales
Coach built Adria
extract from "mr google"!
Quote!!
at a charging voltage of around 14 Volts that yields in 560 to 770 Watts. In modern cars alternators have outputs between 70 and 180 Amps! especially when catalytic converter systems with heating elements etc are used.
tonka
11,035
22,164
Cannock, Staffs
Since 2000
Taken from elsewhere ref a query on a 2008 Ducato motorhome..
"The alternator for this vehicle is part number 504057813 for the 140A model. There are 110, 140, 150 and 180A versions listed."
Top Hat
Top Hat
375
623
Durham
Van Conversion
8years
Thanks @DBK, Yeah thats my gut feeling to, It's getting on for 8 year's since my last trip abroad and trying to cover all bases.
