Anyone have one of these? Does it get hot if used for maybe 10 mins at 900watts IE travel hairdryer?
I don’t have that one, but had a XTH 48v. At full load the fans are full speed and about 35-36deg C. Anything under full load it should be fairly cool. Another thing high power Studer suffer with, is DC ripple, this is when cables are undersized for its load or to long, or, when batteries can’t sustain a stable voltage under load. If dc ripple is high, the inverter gets hot.Anyone have one of these? Does it get hot if used for maybe 10 mins at 900watts IE travel hairdryer?
I haven't fitted it yet. I'm considering various locations depending on how hot it's ACTUALLY likely to get. I suppose I should consider the worst case and go from there.I don’t have that one, but had a XTH 48v. At full load the fans are full speed and about 35-36deg C. Anything under full load it should be fairly cool. Another thing high power Studer suffer with, is DC ripple, this is when cables are undersized for its load or to long, or, when batteries can’t sustain a stable voltage under load. If dc ripple is high, the inverter gets hot.
Also consider you have plenty of ventilation, and clear way for the fan to do its job.
How hot does it get?
