gerry mcg
I need to access the 2x95Ah hab batteries that live under the drivers seat in my x290 Globecar PVC, but I am having issues removing the seat swivel Base,
I've managed to remove the seat from the Base by undoing the 2xT40 bolts at the front of the seat track and 4x bolts at the rear, disconnect the airbag and earth wire and lifting the seat off.
With the seat removed,
Ive removed the 2xT40 bolts at the front of the swivel, plus the 2xT40 bolts at the offside rear of the swivel, plus the rear most T40 bolt at the rear of the inboard swivel. That is all that obviously fixes the swivel to the frame. But it appears fixed by one further rear bolt on the inboard side in front of the rear most inboard bolt
it appears There is a mushroom headed bolt that stops the seat from rotating more than 180deg that is accessible via an access hole that lines up over a bolt to allow a socket to undo it.
Is this correct, and what size is the bolt! I think it measures at 20mm using my vernier, but as usual, I don't have a 20mm spanner or socket.
Before I buy a new socket, can anyone confirm this mushroom headed bolt indeed comes out with a socket and that it is a 20mm socket I require?
Thanks in advance
Thanks in advance
