Struck screw on Leisure Battery cradle
Leeds
C class
5 years
My leisure battery is in a cradle under the van which you lower using a crank. The cradle is held in place by two plastic capped screws. I can’t remove one of them as the plastic cap isn’t engaging the screw thread. I can access the bottom of the screw with difficulty but can’t turn the screw with pliers. Any idea how I can get it off?
Angle grinder.
Or drill through center of plastic through metal stud and out the other side - push the thick part of the drill (the part usually held in the chuck) back into the hole and turn. Use a drill diameter that is 50% of the bolt diameter
remove the nylon head and you will find a hexagonal head on the bolt usually. once the plastic fails, it is beyond repair anyway
Grip the smaller diameter bit of the screw knob with plumbers grips
Thanks for all your suggestions. I finally resorted to using a junior hacksaw to cut away at the plastic until I reached the metal thread then used mole grips to turn that. Safe to say I now need a replacement. Suggestions on what to use welcome as I’m not sure the plastic screw covers are up to the job?
I would just use a bolt, either standard head, or socket head for Allen key. But you could use same type as you had just give it a good coat of copper slip when installing.
I can never understand why modern engineering thinks that plastic and metal screw / nut components are compatible.
The screw thread is probably a standard size. May take a bit of identification, but you'll probably find a standard bolt head or similar at a good DIY store.
Plastic cap is adequate if you keep the bolts greased
Try a standard bolt to make sure you have the right thread size. I'd guess M6 (6mm), but may be M 8. Then google 'handwheel bolt' or 'handwheel knob' and order the appropriate size.
Spray grease on any bits underneath likely to go rusty. It's much better than waxoyl.
Use stainless hex screws or Allen screws. Spray grease as suggested (motorcycle chain grease stays where it's put. Screws are most likely M6.
