Stop dumping... Boiler that is (1 Viewer)
Welsh girl
3,658
3,036
Globecar
How can I stop my boiler dumping water? It doesn't have a lever it's like a blue box with a blue screw top thing on the top and a button which comes out on the side.
I've been told that the button needs to be in to stop it dumping at 8 degrees
I've put a cable tie around it to stop it dumping but its still leaking the boiler is from under the van that is.
mike mcglynn
Jan 6, 2008
2,700
32,552
St. Helens MERSEYSIDE
Autosleeper Warwick XL
A long time now
Hi, the blue screw top as you call it is a valve and needs to be turned to a right angle to the pipework this is then closed then you need to push in the button harder until it clicks and stays in on its own it can be a bit of a fiddle,try that Welsh girl and if that does not work come back on to the forum.:)
Welsh girl
Welsh girl
3,658
3,036
Globecar
I'm not at the van now but will try it later
Trish
Jun 9, 2016
136
187
Teesside
Burstner Elegance
Not sure what type you have, but on our old van, I bought and fitted the Trauma heating element. Five minute job to fit. Not dumping afterwards.
Welsh girl
Welsh girl
3,658
3,036
Globecar
Can you point me to the part that I want please? Out on a walk at the mo.
53,321
149,535
The blue valve actually dumps at 3° so if it's dumping at higher temps it could be a faulty valve. Be warned they are the wrong side of a 100 quid.
Oct 29, 2016
4,502
52,527
Surrey
Carthago C Tourer
@Robert Clark I think you need a holiday:D, wrong thread perhaps:unsure:
Or maybe if you are having a boiler dump valve problem, then just ignore it and bake a cake:whistle:
Les
R
Robert Clark
Or maybe if you are having a boiler dump valve problem, then just ignore and bake a cake:whistle:
Les
I DO need a holiday Les
We’re off again in 3 weeks !!!!
Welsh girl
Welsh girl
3,658
3,036
Globecar
Screenshot_20190223_172920_com.google.android.apps.docs.jpg Screenshot_20190223_173058_com.google.android.apps.docs.jpg Screenshot_20190223_173058_com.google.android.apps.docs.jpg
Can I just take the frost protection valve out and just use a T piece to continue the water flow?
53,321
149,535
golly
2,005
69,581
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
If I have water in the van and the temperature is likely to be low, I put the boiler on low which prevents it dumping or freezing
