step not retracting (1 Viewer)
chris campy
5
2001 ci rivera 141
the step on my ci motorhome isnt retarting when you turn the engine on there power going through the fuse for the step when the engine is running but it wont retract
it works fine with the switch
anyone have any ideas?
TheBig1
17,183
41,165
the D+ feed from the alternator will have a separate fuse to power the step relay in
chris campy
chris campy
5
2001 ci rivera 141
this is what the fuse box and a small part for the step looks like if its any help
chris campy
chris campy
5
2001 ci rivera 141
imgur.com/a/8J07Lxh
ecuses the rough note translations
Jan 31, 2013
135
172
Scotland
CI Cipro 85
im a newbie
Had same problem with my CI motorhome 18 months ago. Stripped step down 4 nut and bolts, greased bushes and bolts reassembled and fitted nylock nuts. Do not overtighten, just nip up. Jobs a good un.
andy63
4,672
15,026
south shields
None
since 1990
there is most probably a switch which is operated by the step when it closes... the relay coil that operates the closing of the step when the engine is running is earthed via that switch, and that switch is most probably stuck and needs a clean up..
Andy
chris campy
chris campy
5
2001 ci rivera 141
Andy
ive had a look on the step motor a few time and cant see any sort of switch unless its inside the unit its self defentily not on the outside of ther caseing anyplace
Jan 22, 2013
1,198
51,822
London SE
A class Adria vision I707
since 1971
Usually the micro switch at the step, water and crud gets into it,
Try and seal the connections with some under seal to stop repeat failure,
irnbru
13,474
30,953
Glasgow
Benimar 264
9 yrs
@chris campy
not the best picture but i really cant see any kind of switch on the unit
Hi Chris, You have used up your 5 free posts so you need to subscribe , Its £15 for the year, well worth it. Just hit the subscribe button at the top of your page.
andy63
4,672
15,026
south shields
None
since 1990
its usually close to the motor but not part of it, and usually well covered and operated by one of the step link bars as it swings up into the closed position if its a conventional step. if its a slide out then the switch is inside the step casing...
Andy
