Starter battery isolation fuse location?
Yorkshire
Burstner Nexxo T690G
Since 2011
We are having to remove the Schaudt EBL226 as it is overcharging the hab battery when on hookup.
We have removed the 50A, and 2A fuses from the hab battery area but need now to remove similar fuses to isolate the EBL from starter battery. However, we cannot find them! Inspection of the battery compartment only reveals those fastened onto the starter battery.
Our van is a 2008 Adria coral 650SP on a Ducato 2.3., and we understand converters often put these inline fuses in other locations.
Looking for a wizard to help:unsure:
The simplest is probably just to disconnect the negative terminal at the battery.
Sorry I can't help, but you are probably looking for 3 fuses - a 50A, 20A and 2A.The 20A is the fridge element supply. Such fuses should be close to the battery, no more than 50cm from it. In fact the manual says 60A, not 50A.
