Sorry chaps/chapesses, another wee toilet thread
Perth
Hymer A Class
Since 2014
Hi, my Thetford 260 fan has stopped working. I know some folk disable it anyway but I’ve just spent £20 on a new filter! I’m struggling to determine whether the fan has gone pop or the PCB has blown.
I’d like to put 12v directly on the fan to see if it works or not. I’m reluctant to try to dig it out yet as this will destroy the foam seal between it and the cassette and I’m not sure the fan can be pulled directly out of the recess if I do rip off the seal.
There’s a four way spade connector nearby which looks as if it goes towards the fan (or maybe the PCB which is perhaps more likely). On the power side there’s 12 volts on two pins and nothing on the other two. The fan will only have two wires. Is there any way to deduce whether the fan is good from this? I do have a 12v source if I can get directly to the fan.
Thanks.
Salisbury
Hymer B678DL A class
since 2011
You need to check the cable with a multi meter to assertain which cables are live etc.
D
DL42846
As above. Test with a multi meter. you can buy them on ebay for around £15. Useful bit of kit to have with a MH. Test the connection to the fan and see if you have power coming through.
G-RMPS
Perth
Hymer A Class
Since 2014
I have a mulitmeter and used it to test the four pins on the plug. I was asking whether anyone knew which of these (if any) connect directly to the fan.
Rochester
Auto-Trail Mohawk
17 fun filled years
My fan packed up, its just a small 40mm or 30mm PC fan that you can get of e-bay for about £5 you want the one with 2 wires, some have an extra 3rd sensing wire when used in a computer. The Thetford replacement is £50. When I took the original out it was exactly the same make/model as the one of e-bay
G-RMPS
Perth
Hymer A Class
Since 2014
Thanks, how did you buy or make the foam seal?
Rochester
Auto-Trail Mohawk
17 fun filled years
I'm struggling to remember the seal, is it square with a whole in it? I didn't replace or make a new one so I must have salvage the original and used that, if it's what I'm thinking of then it was closed cell foam like neoprene, so easily sourced if you need to make a replacement. I remember the wiring was tight as it was trapped under the toilet outer housing.
Sorry I can't be any more help.
G-RMPS
Perth
Hymer A Class
Since 2014
Ok, thanks. I’ll plan to make one from neoprene assuming I can source a fan (if, indeed, it is the fan that’s duff!).
G-RMPS
Perth
Hymer A Class
Since 2014
Mouser.com sell the identical fan for about £10, but with postage comes to £24! You can get similar but not identical fans from China for less than a fiver but delivery could be weeks. I got a sample size of adhesive-backed neoprene for £1.50.
Ottershaw
Hymer S820
First motorhome May 2021
I'm not familiar with this particular fan, however, low voltage fans sometimes get a flat spot on a bearing and stop turning, if a little push gets it working then it's time for a new fan.
