Solar problems
Brian King
Autotrail Cheyenne
Solar panel blew off on our ay home !!!! Long story !!!! However after the incident happened I could not connect the mains as it kept blowing the fuse . can anyone help please
Ive had a new solar panel fitted but I am having problems listed below
The control panel shows no voltage on the engine battery and the switch to go from leisure to engine battery does not light up or activate . The light on the solar control panel only shows battery 2 charging
I’ve had the Sargent PSU and control panel checked , all connections re done and a new engine battery fitted also checked every fuse
Is there anyone who can help please
Cheers Brian
ambulancekidd
Ayrshire Scotland
Swift Kon-Tiki 640
Since 1964 Gosh that makes me feel old.
Are you using the existing cable's? If so perhaps your problems lie there?
B
Brian King
Autotrail Cheyenne
Do you mean the original cables form the panel to the control box or the inner cabling . . I haven’t fitted the new panel I got a dealer to sort that issue
MikeD
London
IH PVC
Since 2012
Sorry I can't help with your problem but welcome to the Motorhomefun.
I am sure someone knowledgeable will be on-line soon.
hellowelcome
Corby, Northants
Coach Built
Sounds if you have two issues, hook up blowing a fuse and Engine battery not receiving charge from Solar and not displaying on Control Panel. The second issue could be a blown fuse between both sets of batteries. Check fuse next to leisure battery. As for the 240 V Issue. I'm at a loss. You might want to check your 240 V connection at the hook up socket. Make sure your disconnected from the 240 V supply.
Manchester
A class Hymer
Since the 80s
As @PhilansMena says, you probably have two issues. What do you mean be 'blowing a fuse'? Do you actually mean that a wired fuse blows and needs to be replaced? Or is there a device which trips a switch and you have to switch it back on?
Is it the hookup post or the motorhome fuse that is blowing?
If it's a trip switch, there's two kinds, to protect against two different faults.
An RCD protects against electric shock and is triggered by small leakages of electricity. An RCD has a 'Test' button as well as a switch.
An MCB protects against short circuits and excessive current. It doesn't have a 'Test ' button, just a switch.
So it helps with fault-finding to know if it's an MCB or an RCD that is tripping.
