Solar panel I am set up right
Durham, UK
Swift Bolero 714SB
Since 2018
Hi can anybody help again, I am looking at my EC400 unit, I have set the select to Engine battery and left the box switched on, with charger switch pushed in, it as not been charging off the solar panel, please be gentle I am a novice (ps solar panel fitted in June by garage)
Jeff
It could be a case that at this time of year just not enough power from the solar,,
If any help you can get the manual here
Could it be that the installer connected the solar panel directly to the hab battery and not through the EC400, so is only capable of charging the leisure battery?
That would be quite common as it’s often easier for them and they don’t have to know the ins and outs of various control panels and systems.
If that’s the case it may be easier to just add a Battery Master or CBE CSB 2 type trickle charging unit to charge both batteries from solar....when there’s enough sun.
Thanks again, might be red hot tomorrow and problem solved 🤪
Not if your solar is not connected to the cab (engine) battery. 😱
I would ask the installer how they installed it and what it’s connected to.
The EC400 should have the 'Smart Charging' system, which should, so long as the unit is left switched on, direct both EHU & solar charge to whichever battery needs it.
As others have said, this will only happen if the installer has wired the panels to the EC400. Do you know if the installer also fitted a separate solar controller, or do the wires from the panel go direct to the EC400 (which has a built in solar controller).
As an aside, there is a limit as to what the EC400 can handle. If you only have a single panel, that should be within the capabilities of the built in controller, although it isn't the most efficient type available.
Hi There is some sort of controller in the cupboard, wired to the solar panel, which always as a green light on
Is there a simple test a novice can carry out, installers garage shut with lock down so can’t really help, was installed in June
Jeff
See if you can trace the other two (there could be four more) wires coming out of the controller.....to see if they go to your ec400 or your leisure battery.
Great thanks again, check hopefully tomorrow 👍
Jeff
Photograph of the box with wires going in may help. I put photograph on here and got the answer. (y)
If the solar regulator/controller is wired into the EC400 it should be into the socket P14 in the back of the unit to enable the solar smart system control in the EC400 to be used to charge both batteries as required. .
If the solar regulator/controller is wired to only the leisure battery , as suggested, fitting a Battery master would keep the starter battery charged up at the same time as the leisure battery from the solar panel.
Is your leisure battery easy to access and do you have a multi meter, if yes, with your ec400 still switched to cab battery check the voltage of your leisure battery on a sunny day and make a note of the reading, then cover the whole of your solar panel and check the battery voltage again, if you see a fall in the voltage the panel is more than likely wired straight to the leisure battery.
