Solar Panel Connection
Dave dB
Kent
Bailey AA665
I'm a newbie March 2018
Hi, does anyone know if the solar panel is linked into Hab control panel or PDU or both?
Some vans have solar regulators built into the main PSU / POWER SUPPLY.
Example my Autotrail has the Sargent EC500 unit, all it needs is a connector plugged in from the solar panel. The PSU then does the regulation to the batteries and has smart facility to do both engine and leisure batteries.
Thanks Geo, I've had the solar panel fitted and for some reason my 5amp fuse for the control panel in the PDU has blown 5 times since Feb the first being the day after the panel was fitted. Having been in touch with the company who went straight on the defensive and did not even offer to take a second look for me although they are near on 2.5 hours away. So I wanted to know if they are connected some how before I take further action.
My 100w panel says "connect battery end First" Then plug the panel in.
Mitch.
Hi Dave
Your profile says you have a Bailey van?
I'm familiar with solar setups but not what kit is in a Bailey, so what "PDU" and control panel do you have? Do you have a separate (mppt or pwm) solar controller?
This info would help give a better answer I think
Steve
Fit a separate Solar Controller you can get them with twin battery output. Once it has charged the habitation battery it will keep the engine battery charged up. Some of the Sargant Control Panels need to be switched on to work.
