solar on/off switch
TCG
Salford Priors
Autotrail Delaware
as anyone fitted one of these, are they any good or can you advise of a better switch for my solar panels (for the winter)
I use something similar but only really to disconnect if working on something. Otherwise why would I turn off the solar in any season?
want to reduce the amount of charge to lithium batteries in the winter (keep them about 80%)
If you have a victron Bluetooth MPPT you can turn it off in victron connect if not just use a cheap double pole MCB and use as a switch should be DC rated but the amount of times you use it shouldn't be a problem if not.
I have the same as the OP picture. There have been criticisms of the quality although I've had no problems with mine.
  • Thanks
Reactions: TCG
Mine is very similar but I intend to replace it with a midi fuse. Not as convenient but much safer. Those Chinese circuit breakers aren't made to any standard and I don't like leaving it unattended. Funsters have had them fail.
  • Thanks
Reactions: TCG
If you have an app for the batteries you should be able to change the SOC on it
  • Thanks
Reactions: TCG
Oh Thanks i do have a Victron blue tooth Mppt - problem solved
If you want an actual issolator switch i used these
Although they are still insitu i control the charging via SOC settings on my bmv712 and 2 100A dc SSRs.
that looks a bit more robust is that battery switch fused
No fuse required, the panel can only deliver 10 amps and the cable can handle that easily 👍
Reactions: TCG
lots of those have failed on the various van forums and facebook chuck it in the bin
