Solar controller question - help please (4 Viewers)
Mr Mousy
620
3,106
Llanelli
Hymer S840
First moho 11/2013, second 11/2014 current from 09/2019.
First things first... I know nothing about solar systems or electrical things other than turning something on and off.
The Moho has a 100w solar panel fitted with a controller and display as shown below.
Even in the bright sunshine (when in France in the summer) I thought the output was not very great - 4a ish.
So to my questions...
Do solar panels output deteriorate over time? The panel is about six years old. If I replaced it would the output improve?
The current controller is 20ah (whatever that means) the user manual says it is suitable for one 100w panel.
If I swapped to a MMPT (?) controller would it substantially improve the performance? I have no idea what the difference is between MMPT and a standard unit.
We have two x 125ah batteries plus the standard engine battery.
The 0.4a and 19.3v was this evening as the sun went down. The 7.3a is the maximum it has ever delivered.
We are fortunate that the van also has an Efoy system, however I would love to have free electricity!
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
What we don't know is the battery voltage. As the battery voltage rises so the charging amps falls.
With a voltage of 12v I would expect 6A plus. but with 13v maybe 2A in the same light.
Mr Mousy
Mr Mousy
620
3,106
Llanelli
Hymer S840
@DP_JAY thanks for the quick reply. I will check the battery display and report back.
andy63
4,672
15,018
south shields
since 1990
hi.. your figures don't seem too bad.. the best output you could expect from a 100w panel would be in the order of between 5 and 6 amps i think... and that would have to be under good sunlight with the battery in need of that sort of output.. a controller rated at 10amps would do a 100w panel... if yours is a 20a controller it would comfortably take another 100w panel ..
andy
jollyrodger
6,282
26,425
Devon/Cornwall
'Obby
Since 1968'ish
I have the same controller,and in Javia Spain now so plenty if sun ,but with 200w of solar and 3 x 110amp batts .
both batteries in your pics show batteries full charged .the red lights. are they fixed red (charging)
or flashing red( fully charged )
and in float mode ,? Personally I see an mppt controler as an unnecessary expense ,but my opinion only.
Mr Mousy
Mr Mousy
620
3,106
Llanelli
Hymer S840
Thank you all for your replies.
The red lights were flashing - which you say is fully charged.
The voltage of the batteries is okay 13 ish - the hymer display shows 90% charged.
I don't understand why the % charged does not go back up to 100% as it does when on hookup or if I turn the Efoy on.
Any ideas?
@jollyrodger @Taran_Las @andy63
jollyrodger
6,282
26,425
Devon/Cornwall
'Obby
Since 1968'ish
Bobby22
1,537
6,408
Rapido 680ff
since 2013
An MPPT regulator is most suited to 170 watts and above. Your PWM controller is best for lower than 170watts.
Unless you are using a inverter your system looks a good setup.
4amps with a roof mounted panel, ie not square on to the sun, is a decent return with a 100w panel.
andy63
4,672
15,018
south shields
since 1990
if i understand you your asking why the power management system doesn't show an increase in battery capacity when charged by the solar but does when you are on edu or efoy .i would its because the solar is wired directly to the battery and not through the shunt which records current flow in and out of batteries... so your solar isn't been recorded the way its wired...all i can think of. and hope I've understood your question..
andy
Feb 24, 2013
13,090
101,509
Bolsover, Derbyshire
Hymer S800
not long enough
csvk m z;sv jkd ;gvk cz/ gmv,nxn hv zg.hxl
did that help Martin?
more importantly did anything not work on your last trip?
leave well alone, as in Yorkshire, if it ain't bust don't try and fix it (y)
Jan 8, 2013
8,491
11,530
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
How flat do you allow the batteries to go? If you are plugged in regularly you don't need solar. Run the batteries down to 12 ish volts and see how much charge you get. You might see 10amps plus.
Mar 26, 2009
8,164
11,229
Yr Wyddgrug
Hymer B678DL
To prove Andy's theory do you know if your eFoy system is plumbed through your electroblock?
Mr Mousy
Mr Mousy
620
3,106
Llanelli
Hymer S840
David, you of course are correct. I should only think about these things when they do not work at all.
I really appreciate all your input to my questions. I think @andy63 may have sussed it as the solar input does not go through the electrobloc and therefore does not show on the maintenance display. Maybe i should judge the state of my battery charge by the voltage and not the % charge shown by the control panel?
@jollyrodger Thanks you for the user manuals
andy63
4,672
15,018
south shields
since 1990
I asked a question on a thread a while back about the problems of connecting solar direct to batteries and not through power management systems... my power management panel had a max solar capacity of 120w I was told and I had 280w to install.
I was told that as long as the system didn't monitor and calculate the current in and out to determine batery condition then I should be OK. .. and so far so good....but in your case the system does check these things and your solar isn't taken into account....
Point I'm trying to make rather badly is do you know if it does cause a problem... ie can you be sure your batteries do get a good and full charge on hook up as the system will see the elevated battery voltage from the solar connection and adjust charge rate to suit...
again hope you get what I'm trying to say and hope someone may be able to give a better explanation of possible problems with such a set up..
Andy..
Bobby22
1,537
6,408
Rapido 680ff
since 2013
Andy..
Andy would the system top up to full during darkness on EHU or would it not be long enough to fully condition the battery bank?
I ask this as i have mine on hookup at home with 120w solar.............would it be best to switch solar off at controller in this situation?
andy63
4,672
15,018
south shields
since 1990
Hi Bobby. . Seems logical that it would charge fully on hook up off the built in charger..
Again can only comment on the charger in my camper..
It takes around 4 hours to reach a float charge after the bulk and absorption cycles... its a sterling charger and rated at max 20A.. I quite often just leave it on float for the day and the power management snows a charge of 200 to 400ma during that time...
The new van I have no idea what it's doing as I've not had the time to check things out and it doesn't have a pmp in it yet... that allows me to see things other than voltage at a glance..
Andy.
Bobby22
1,537
6,408
Rapido 680ff
since 2013
Andy.
Hi Andy i was looking at an MT-50 , it plugs straight into my controller, to see the inputs, condition and the like cheap on ebay. Are they any good?
andy63
4,672
15,018
south shields
since 1990
No idea Bobby. .. you are talking about something that shows the solar output and battery voltage etc I think.. I'm talking about a panel that monitors everything that goes in and out of the leisure battery bank .ie voltage current and net amp hours... from any charging source.. it's the sterling unit... pricy but I've found it fairly reliable indicator and may fit one in new van..
Andy
Bobby22
1,537
6,408
Rapido 680ff
since 2013
Andy
Yes i remember the unit you had in your other van, it was a great piece of kit. I'm quite happy with my set up and had no problems with it but for £20 i could get some figures just for reference and peace of mind..........bearing in mind it needs no skill or thought to install.
Mar 26, 2009
8,164
11,229
Yr Wyddgrug
Hymer B678DL
Martin, apologies for the delay. I think Andy's theory is correct. You are charging your batteries through the back door and the electroblock cannot account for the difference.
Mar 26, 2009
8,164
11,229
Yr Wyddgrug
Hymer B678DL
@Mr Mousy
Constant monitoring is required methinks:D
Check voltage levels with a meter on the hour every hour:eek:
Mr Mousy
Mr Mousy
620
3,106
Llanelli
Hymer S840
I've come to the conclusion that I am probably worrying about nothing! If I can find a cheap Schaudlt LR1218 that integrates with the Hymer control panel and replaces the current solar controller (it will update the main control panel % charged) then I will do that. If I do replace the solar controller what would you blank off the hole with where I remove the defunct solar display?
