Hi all in the past I’ve ran a cable directly to the leisure battery from the solar controller and another from the dual of the controller the the vehicle battery, simply because the solar controller was close to the batteries. I had the cable pre installed by Niesmann in our new Arto and basically its been wired that the end of the cable comes out with all the electronics in the garage. This is great but I need to know where to connect to the leisure battery and where to connect to the vehicle battery? I’ve been trying to meter things out but ther is way to many positive 12volt terminals, I think there is only the one large black negative but this would mean the batteries are all linked? Looking at the pictures the blue box appears to have the connections but the cables are so thick I don’t think I’ll be able to add any thing there is a 6amp spade connection with a picture of the vehicle battery which is fine if it feeds back to the vehicle, the picture of the 3 studs are all 12 v positive and the small blue bridge is positive.
Im sure although this is a Niesmann Bischoff it’s going to have the same electrics as other vans, any advice would be welcomed it’s got to be easy but there are never any wiring diagrams.
