Simple answer where to stick it ?
Hampshire
Chausson 640 welcome
Since October 2019
Have my French and German air stickers - in plain English where should they be stuck ?
Bottom right hand side of windscreen as your sat in the seat.
Ditto that.....
Mine are fixed in bottom corner of screen on left looking from the front of the vehicle from outside, which I believe is correct.
......and again. (y)
Cheers,
Jock. :)
Upvote 1
What everybody else said - bottom right hand side of windscreen as you look forward from inside the van.
Actually that's the near side so far as the relevance of the stickers are concerned.
Agreed if LHD but as mine is RHD and I'm guessing the OP's is also RHD then it's Offside.
I fitted all 3 of mine on a strip of perspex and they go from bottom corner upwards attached to screen .saves having to get new ones when the screen needs changing.
That's what I did
Richard, I laminated mine, then placed then in clear tax disc pouches, which stick to the windscreen.
Been there and done that, re losing a Plakette due to a cracked screen. :doh:
Cheers,
Jock. :)
Stick ours on a plastic pocket that has gone through the laminator so a semi rigid sheet so only on display when required not permanently fixed.
I think I need to beg, borrow or steal a laminator now, you see how curing one problem, leads to yet another:rolleyes::unsure:
LES
What are Air stickers ?
The actual instructions require the disc to be stuck to the windscreen but let's not let foreign rules get in the way of anything . . .
Upvote 1
