Dazz
Hi all I have a tub of sikoflex 512 and I was just woundering if anybody has used it to put a seal around the bath in the house just wondering if it’s good for that job
Hi all I have a tub of sikaflex 512 and I was just woundering if anybody has used it to put a seal around the bath in the house just wondering if it’s good for that job
Why?Good idea to fill bath before sealing too
Yours is outside in the back yard anyway Lenny and there called Tin baths not cast ironWhy?
My cast iron one ain't going to move.
You make yourself look silly when you use personal opinions as expert knowlegei think this has been a passed down DiY myth for years !
i have fitted dozens of baths and never had a problem not filling the bath before using a v good quality silicone sealant - even long before the days of anti mould sealants.
most modern baths will actually expand when filled with hot water (pressed steel, acrylic) so if the bath was filled with hot water then the gap to be filled will be smaller as the bath has expanded and when the bath contracts when empty there would be extra strain on the silicon pulling it apart as it stretched to fill the bigger gap. it would be under that 'stretching' pressure whenever the bath was not being used, which is far more often than when it is being used, and only 'normal' when the bath is being used. any sealant is more likely to fail when under constant pressure.
if the bath was filled with just cold water before applying silicone, then in theory it would contract, making the gap bigger. when you then applied the silicone and the bath, when empty, returns to its room temperature 'size', it will constantly compress up against the tiles when not being used and even more so when it is being used as the bath will expand compressing the silicone even further. that can cause tiles to be forced off the wall if they havent been fixed properly, especially if the compressed silicone can get behind the tile.
my advice and experience would be to suggest that you fit the bath properly, then tile and then apply silicone without filling the bath .....
Still got the tin one mummy used to bath me in that would have been 1950/51, used as a garden planter now, you don't get galvanizing like that these days.Yours is outside in the back yard anyway Lenny and there called Tin baths not cast iron
Or Mummys.Still got the tin one mummy used to bath me in that would have been 1950/51, used as a garden planter now, you don't get galvanizing like that these days.
Well im not here to convince you of anything, it appears plumworld, Wicks, B&Q, and the like all suggest filling the bath also plumbers Forums such as these <Broken link removed> also agree, so im quite happy with their advice.View attachment 393952View attachment 393953
If you can show me where a product specifically made to seal gaps in between bath and tile tells you to fill the bath with water then i will be surprised
