Hi All,
I should be grateful if you could help me out with an issue on my Elddis Autoquest 2014 in which the top front, back top and bottom (orange) marker lights are not working. The only thing I could find to be a problem is that a 10 amp fuse was blown by the driver side / below safety belt wiring loom (see photo / yellow circle) and although I replaced the fuse it blew straight away when I put on the lights (from the main light stalk).
I then took out the bulbs which all appear to be working, and disconnected the earth wire on the bottom marker lights. Unfortunately, when I tried a new fuse to what I thought would be a bulb free system, the fuse blew again.
Although, this may be a visit to the Dealership, but I thought I would check with you guys first for any thoughts?
Thanks.
Thanks.
