RichardandKaren
In France at the moment and have found a small leak from my water pump. Noticed last night that pump fired up every couple of hours to keep pressure up so assumed there must be a small leak somewhere. Checked this morning and damp patch under van. Took cushions etc off sofa to expose pump area. See it’s damp. When pump runs there is a small leak coming from where the black plastic housing attaches to the metal pump body. I have tightened the 4 screws that affix plastic bit to the pump but still leaking a bit. If I undo the screws and separate the two parts can I apply some form of sealant to the join and then re-screw the plastic bit back on? If so, what sort of sealant should I use? What type of place in France might sell such stuff. If I have to leave it I don’t think it’s the end of the world, I’ve stuffed a spare towel around the leaking area and will only turn the pump on when I want to use taps/shower. Any advice would be appreciated.
