I don't have a self build though I have done quite a bit of rebuilding of the coachwork after getting leaks at roof level in my CI Carioaca 644.
Working from inside I replaced the rotten wood and replaced internal panel with plywood. I resealed the junction between the aluminium roof skin and the side frame. The joint aluminium moulding was bedded and screwed down. I also resealed the junction between the aluminium roof sling and the front overact fibreglass moulding. I used Sikaflex and proprietary none setting sealant to achieve this. I thought I had solved the problem, however, I have signs of damp on the nearside just behind the passenger door of the Fiat Ducato cab door.
A long time ago I built a sailing dinghy using the stitch and glue system to join panels in the hull. I am thinking that I could do similar with resin and tape on these roof joints. I don't intend to fibreglass the whole roof - yet!
Has anybody done similar?
